Tablet CHUWI HiPad XPro does not open WiFi
My tablet is S/N ZHIpXpEY00221200452 . I put it on Factory service mode, but it still not open WiFi . It see WiFi networks but can not connect to them. May be need it to be reboot. I need properly software and instructions.
OS
How to Manual and files
Thank you. I tried but I still have not success…
@manonegra222 can you see if you could help
While at the desktop, try pressing the power button for 16 seconds to try to restart the Wifi and Google services. If after that, it stays the same, I would try to set up a connection on the tablet with fixed IP to see if it is able to connect to the router
Hello, friends
I tried to connect to Network by WiFi, after did that you explain. The result is the same.
Best Regards
Milen Krastev
Mobile phone: +359 893344188
second mail: milen.kr.950@gmail.com
-------- Оригинално писмо --------
От: Rafael via CHUWI | Official Forum notifications@chuwi.discoursemail.com
Относно: [CHUWI | Official Forum] [Download&Tutorial] Tablet CHUWI HiPad XPro does not open WiFi
До: milen_5002@abv.bg
Изпратено на: 31.05.2024 20:11
| manonegra222 Líder
May 31 |
milen_5002:
Mi tableta es S/N ZHIpXpEY00221200452 . Lo puse en modo de servicio de fábrica, pero todavía no abre WiFi . Ve las redes WiFi pero no puede conectarse a ellas. Es posible que sea necesario reiniciarlo. Necesito el software y las instrucciones adecuadas.
I saw that after use operation you recommended to me how connect by WiFi was written "Authentication problem ".
Best Regards
. Milen Krastev
| manonegra222 Líder
May 31 |
milen_5002:
