I bought my Chuwi laptop less than 3 months ago. At first I loved it but now I wish I never bought it! It gives me nothing but a headache and I am beyond frustrated. Now I wish I would have listed to all of the warnings in all of the reviews because I thought the laptop seemed like it was trustworthy and it was reasonably priced etc. The charge if I am lucky lasts 30 minutes and that is even after giving it a full charge. Then it never wants to turn on. At times I keep trying over and over and over to get it to turn on and this also is very frustrating. I keep it up to date and have downloaded all of the updates. Unfortunately it is too late to return it so sadly I am stuck with this lemon-hunk of junk…oh I almost forgot…the original charger that came with this laptop stopped working completely after only having it for one week! So needless to say I couldn’t even use it for 2 weeks until I got the charger cord replaced which is also sold by the Chuwi company. Has anyone had these problems that has found a “fix” or am I just completely out of luck? Thank you in advance…
At last you could tell which laptop you are talking about
It does not seem normal
It may need repair
I dont have any paperwork for the laptop I bought it online from Walmart. How do I figure out what model it is? Thank you for your response and help.
Hello Serpent,
In the online purchase you made at Walmart it may have the model of your device.
Also, if you check the backplate of laptop, there must be engraved in somewhere the Chuwi brand and some numbers, which will be model and serial number.
