How much will the repair cost? It’s just that now it’s no longer possible to use this laptop at all; after an hour of operation, the processor frequency becomes 1 GHz, and everything lags and slows down. Tell me what needs to be done to send and how much will it cost?
You need to write to service@chuwi.com as you need to send to Hong Kong. My colleague will inform you of everything.
Please tell her:
Your model device and Serial number
Where do you currently live
That you do not have warranty because you bought in another shop, not official
You already purchased a battery from us but… still same problem
When you write please let me know, so i will check if we received the email
Hello, I am writing again. I still have not been able to send you the laptop (I wrote by email that they do not want to send it, citing the fact that the hard drive may contain information that can harm China and that there may be alloy batteries. I took them out, but they still did not want to send it). Support by email said that then the only thing left to do is take it to the service centers and fix it at your own expense. I went to 2 services, one said “well, your power supply is bad, buy ours, everything will be solved”, in the end I bought a power supply from them, but nothing changed, in the second they told me “well, we do not know how to fix such things, they buy Chinese laptops and then rush with them to service centers, it is easier to throw them away”. They even refused to buy it for spare parts, I do not know what to do with this. Maybe there is some way to get a replacement just like that (it is possible even if the laptop is weaker or refurbished or a nettop instead of a laptop)? I can demonstratively break it on video if it helps prove that I am not a fraudster and not trying to get some kind of super benefit from you. It’s just that right now the laptop is dead weight and I can’t do anything with it at all.
