Thank you so very much. This has been a problem for me for months. This fixed my touch screen driver perfectly.
Now that everything is correct and all devices work, make a copy of the drivers and keep them in case they change with any Windows update. Use the freely available doubledriver application on the internet
Great job, my HI10 pro return to work. Thanks for help.
Hi guys, after touchscreen replacement axis are switched (swapped)
vertical axis now horizontal, could you please help me out with this problem?
I had the same problem and I fixed it as you described.
Thanks a lot.
thank you very much <3
