Ubook n4100 screen touch not calibated
I just received a UBook N4100 bought from Amazon UK. On arrival it would not boot and windows recovery just hung for 4 hours so I reinstalled windows. All is well except the touch screen and giro. So I downloaded a driver set from a post on this forum and installed both drivers. Touch now works but it reads the touch in the wrong place so it may be I used the wrong driver. Please supply a link to the correct driver for this model. It would be better to fix it than return it to amazon.
Many thanks
Not to worry, found the right driver. All sorted.
hola.me pasa lo mismo,que drivers has instalado?
gracias
Which driver did you use?
I backed up all the drivers from my UBook. Download it and try to fix your drive. Make sure you are using windows 10.
here is the download link: UBook 11.6 Windows 10 Driver
