Where do I find missing drivers for Hi12 after a clean install?
I did a clean install of Windows 10 on the Chuwi Hi12 with many drivers for its components provided inbox. However some devices are not working due to missing inbox driver support.
Example: Missing is the driver for the Chuwi Hi12 touch screen.
Where do I find the missing touch screen driver, a url that points directly to the appropriate driver would be nice?
It is logical that, after a clean installation of Windows, the system does not recognize the drivers of non-Intel devices. This happens on any device of any brand.We must then install the drivers that Windows has not been able to install.To do this, after downloading the drivers of our tablet or laptop model and unzipping them into a device storage folder, disable Windows protection for the installation of unsigned drivers.To deactivate this protection, press start, restart with the shitf key pressed, and restart now. When you restart, an advanced reset screen will open in which you must press 7 or F7 to deactivate the protection and it will restart normally.
It is time to go to the device manager, by clicking on the start button with the right mouse button and in the menu choose device manager, and see in the device tree the drivers that are not correctly installed. (they have a yellow triangle).You have to click on each of them with the right button, driver properties, update driver. On the next screen, choose the option below “search for driver software on the computer”. On the next screen “choose from a list of available drivers on the computer” and on the next one you must click on the use disk button; The browser will open and select the folder where you have unzipped the downloaded drivers, checking the option to search in subfolders.The system will install the device driver. You have to repeat this process with each of the devices with a yellow triangle. Keep in mind that if you restart, the protection will be activated again, so you must activate it again when you have to install a driver.
Maybe my question is too simple but it is not answered yet: Where do I find all the drivers for Windows 10 for a Chiwi Hi12?
A url that points directly to the zipped drivers file would be nice. I don’t know where to go in order to download all the drivers for the Chuwi Hi12 - that’s my pain point.
Cool, got it. Thanks a lot, manonegra222.
Resolved, I found all drivers for Chuwi Hi12 after a clean Windows install zipped in a single file for download at
Driver installation went well. Device Manager no longer shows any unsupported nor unrecognized nor unknown devices. Perfect.
This is a dead link. Does anybody have a current link to download drivers for a H12 dual boot tablet? Q64G45171002442 model CW1520
Android working fine. Windows hung during an update so I reinstalled from the Microsoft website. The latest version has no drivers for the modem so I’m unable to get it online to update it further.
Grazie mille, manonegra222.
Would you mind trying this source? Lots of windows drivers all of them are for free. You even don’t have to pay anything. Just enter into the website. Search for the desired driver and then start downloading.
Source- Comment mettre à jour les pilotes Acer FHX2153L
