Where to buy replacement\additional chargers?
Is there an official channel from Chuwi where you can buy additional or replacement chargers for laptops like the GemiBook Plus N150? I’d like to get an extra charger or two for mine.
I ordered a charger that looked identical on Amazon, with the same voltage and wattage, but the barrel jack was the wrong size.
I found the exact same model charger on eBay by searching the model number printed on the power adapter itself, but it’s listed for $75 for some reason.
I noticed that chargers are absent from the Accessories section in the Chuwi store, so where can official chargers be purchased?
Thanks!
