it is lost and the message is Gateway not available. After restarting the wifi adapter the signal returns but after a while is lost again. I have 5 other devices connected to my router and they all work without problem. Only Herobook pro has this problem. Do I need to install a better driver?
Greetings
Robert
format chuwi Windows, chuwi work fine after new clean istallation, use glk driver to set all driver not found during installation.
you must used windows 10 2004 may update, it’s more stable
Thank you Giorgio for your info but I was looking for a less complex solution such as a better driver for the RTL8723B wireless lan usb 2.0 . I am now using a usb wifi adapter and disconnected the RTL8723B no problems anymore. I will consider however to use your solution but am not sure if some new issues will come along by doing so.
Best regards
Robert
After the may 2004 update the wifi became more stable but still a sudden disconnect problem occurred.
Now I installed Easy Driver and after installing the new drivers the problem did not occur anymore. So my problem is solved.
Greetings
Robert
How have you done the may 2004 update? Because I tried with microsoft tool but at the end It cancelled installation
scarica Windows 10 creator tool, crea dvd iso di wondows 10 , usa una unita dvd rom separata e fai partire il dvd di installazione. Durante i vari passaggi, arrivi dove ti chiede di scegliere la partizione, mettilo sulla terza, prima formattala ovvio.
Sì più o meno ero arrivato a un passo dal piallare tutto ed installare Windows 10 2004 via USB. Poi mi sono mi sono chiesto: come faccio ad attivare la copia? E: se per caso qualcosa dovesse andare storto come faccio a tornare indietro visto che il computer non ha partizione di ripristino?
Così mi sono fermato ma continuo ad avere ogni tanto problemi con il wifi ed il notebook che si freeza forse causa throttle. Diciamo che l’N4000 fa giusto il compitino e niente di più.
Non c’e problema per l attivazione, Windows si attiva in automatico, riconosce la licenza proprietaria del chuwi. io ho installato il 2004 senza problemi, devi solo metterlo nella partizione 3rd.
quello che non ho compreso, e che ci sono altre partizione sul ssd ma non riesco a capire la loro funzione se sono di ripristino o backup. comunque le ho lasciate li, per non invalidare la garanzia. metti i driver che scarichi da questo forum su una pennetta e la metti nell’altra usb.
a fine installazione del 2004 , ha solo un driver da cercare e lo fai trovare sui driver del chiuwi. tutto il resto sè’ configurato in automatico senza forzature compreso il wifi.
