DavidTF
September 6, 2025, 4:58pm
1
Hi, I have been having issues with my mini pc waking up from sleep un-normally. It wakes up normally most of the times but sometimes it just wakes up and after 3 seconds it goes blank and the power button doesnt respond (not even after hold 20 seconds). Please, provide a bios update file or a driver that fixes it. I don’t want this problem with my pc!! It’s a expensive computer after all! Thanks.
S/N: SAUBoxIZ1C250300202
Windows 11 Pro
AMD graphics driver version 25.8.1
Chipset driver is stock from driver download
Bought from chuwi.com
Bought June 30th
You can contact support, you have the information on the Chuwi website.
Mrb
October 2, 2025, 2:58pm
3
Hello I have exact the same issue any solutions ? Maybe a bios update ?
My device
SAUBoxIZ1C250300071
Mrb
October 2, 2025, 3:21pm
4
Hello did you get any help / solution for this issue ??
You can check your Windows installation with:
SFC or DISM
You can start Windows in Safe Mode.
You can download a version of Linux:
Ubuntu or Linux Mint, burn it to a USB drive, and boot without installing.
Mrb
October 2, 2025, 5:44pm
7
The issue occurs also on catchyos ( steamos) so… it’s a bug.
I have experience installing Windows, so I’m suggesting you run some checks.
Safe mode is for detecting problems with application installations.
Mrb
October 3, 2025, 1:41am
9
No issues with installing anything…. It’s most likely bios issue or bad QC at factory… any safe mode won’t fix anything stop writing about it.
I’m just trying to help You.
I have no further suggestions than: You should contact Chuwi support.
