AuPad CW1638 snapdragon 685 After a while reboots and freezes in boot screen
Hi.
I have bought 5 AuPads and the first two that i have opened have the same problem.
When i set them up for the first time they work fine and after a few hours they reboot and halt on boot screen. The only way i can bring them back is to wipe data. But after a few hours they freeze again.
The SNs are
ZAuPadKK1A241001097,
ZAuPadKK1A241001108,
ZAuPadKK1A241001109,
ZAuPadKK1A241001105,
ZAuPadKK1A241001099
They where all bought from local electronics store before 10 days.
You have to complain to the store where you bought them.
Well… this is not the kind of answer i was expecting…
One option is to complain to the store but the reason i am writing here is because i was expecting something more technical…
Is there any known issue ?
does any body else had the same problem ?
Is there any firmware that i can try ?
You can write to technical support through the Chuwi website.
My opinion is:
When you buy a device and it doesn’t work as it should the first time you use it, there’s only one solution: return it.
