CHUWI Aerobook second screen does not work
Hello, I got the following problem:
Today i received a new monitor and I wanted to connect it to my Aerobook. I connected it through a HDMI-cable and a docking station (cause the Aerobook has no HDMI plug).
Unfortunately my monitor could not receive a signal.
So I was wondering: Is the Aerobook not able to transmit video through HDMI?
After that issue I did research and found out that seemingly the Aerobook can only do video transmission through USB-C?
So a USB-C to HDMI adapter should work?
I really hope for a solution!
Thank you!
-Felix
Chuwi AeroBook has mini HDMI output and to connect a monitor you will need an appropriate mini HDMI to HDMI cable
Thank you very much! I did not realize that at first.
I have now bought such an adapter and it works!
Thx again! :smiley:
I was able to when my comp was working however it caused my laptop to perform slowly as well as other issues upon unplugging/plugging it back. And I know my additional screen was compatible as well as the HDMI I was using. I even tried a docking station which also had issues with my Chuwi. I almost wish I had bought a Dell or hell even an HP at this point. Hope this helps!
