CHUWI BIOS Firmware Hi10 X N4120
I contacted Chuwi support and got a file with a .bat executable that flashed the firmware to version 7. got 6 GB back but still no audio device installed. Tried the BIS from this forum. Flashed version 5. Get 6 GB but no audio device.
Is there a setting in the BIOS to enable the sound card. I searched “advanced settings” but found nothing.
I found the driver for my Hi10X with unknown Inteel HD sound.
From this link PC Audio Codecs > High Definition Audio Codecs Software - REALTEK I dowloaded the second item in the windows list. Named “0009-64bit_Win7_Win8_Win81_Win10_R282.exe”
Hope his helps.
Hello Chuwi Team,
CHUWI HI10 X + N4120 + No sound, missing 3GB RAM after firmware upgrade, I install a fresh copy of windows however the problem is not fix.
Serial # HI10 XG128G21020885
Windows:20210119_V1.0_Beta亿道
Drivers:hi10X Drive.亿道2104.rar
Should I reinstall Windows using the file you sent?
Will I need to do some BIOS flashing?
Try to install first the drivers, and if that does not work, then reinstall the system and then the drivers.
No bios needed
