Sorry posted in the other thread by mistake. For completion purpose:
I use the newest EndeavourOS (kernel 5.18) with Gnome as desktop environment which uses wayland. Display rotation works as soon as you install iio-sensor-proxy, it also works only without a keyboard connected but i’m sure this could be changed somehow.
For sound I only went into alsamixer switched soundcard with F6 to sof-essx8336 and pulled all sliders up and unmute everything. Haven’t tested which slider actually affected the sound.
Only thing currently not working for me is to suspend but haven’t looked into this so far.
Buongiorno, ho acquistato Chuwi HI10 Go con intel N5100, ho provato le seguenti distro: Fedora 36 Gnome (sia con kernel 5.17 che 5.18) funziona anche la rotazione automatica, non funziona l audio e poi il touchscreen funziona al contrario.
ho provato inoltre Clear linux stesso problema
Hello, I bought Chuwi HI10 Go with intel N5100, I tried the following distros: Fedora 36 Gnome (both with 5.17 and 5.18 kernels) automatic rotation also works, audio does not work and then the touchscreen works in reverse.
i also tried clear linux same problem
just checked. there is a mic if you switch in pavucontrol the configuration to Pro Audio but it is really quiet for me so there are sure still some issues with the sound.
Ah! The sof-firmware! It did the trick! At some point I heard some sound but it was very low (even if all possible sliders were up) and since a reboot, everything looks ok software wise, but there no sound at all comimg out of the speaker
