I clean installed a Chuwi lapbook 12.3 but after that i have no sound. i cant find anywhere the drivers for this laptop. does it share drivers with other laptop of chuwi? also how do i install the audio driver only?
Chuwi Lapbook 12.3 No sound
Yes, the drivers are the same as the LapBook 14.1 ", but I extracted them from mine so I share them.
They are copied with the doubledriver app, which is freely available on the internet. Simply run the application and load the drivers into it with the option restore, load dirvers and point to the folder where you downloaded the Zip file. Once the application has the drivers loaded, you must indicate which ones you want to activate. As you only need the sound uncheck all but those corresponding to this device.
