I am going mad trying to get the sound work on a CHUWI CWI535 LapBook. I have just clean installed Windows 10 Home and everything went ok but the audio sound driver is missing. There is an exclamation sign on the audio driver. Where can I get the Windows 10 audio driver for this model?
The easiest for all of us would be to have an official web page with the drivers of every model of CHUWI laptop, and not having to ask here for a driver.
Thank you so much, Biosham, for your quick answer. But I’ve tried to install your sound drivers, but I still have the same issue. I’ve tried everything even installing them as unsigned drivers, (F7, etc).
When booting the laptop with Linux Mint I can check that the audio sound card is working, so it is a Windows driver only problem.
Accordind to Linux it is an Intel sound card: “Intel Corporation Celeron N3350/Pentium n4200/Atom E3900 Series Audio Cluster (Rev 0b)”.
I’m really desperate, I’ve installed thousands of Windows systems on laptops, but I’ve never seen anything like this.
Reboot your Windows (I’ve installed 2020 May Update, 2004) for unsigned driver installation and go to the device manager right clicking on the audio device (with an exclamation mark triangle), go to properties and update the driver searching on the previous downloaded and unzipped file (drivers all lapbook 12,3.zip).
It is important to search on the whole file checking the option to search in subfolders. The driver will install, but two new unknown devices will appear. Do a new search on the same file for the new devices and after rebooting your system, voila! everything is fine now!
There is no “best” driver. Every piece of hardware has a unique driver, and you have to obtain the driver from the manufacturer of the device. Sometimes you can find an older or newer version of the driver and it may work better than what you got now, Here is a complete guide on how to download or update drivers for Windows 10.
Hi, I’ve the same problem; CHUWI CW1535 WINDOWS 10 NO SOUND AT ALL; your drive is not more available on the link page. Could you please re post it? I need to use this computer soon as possible and no way to buy another one at the moment.
