I did a full drivers backup for my Windows 10 Chuwi Ubook X 12". I’m sharing the link to it here as I’ve heard quite alot of members are having trouble looking for one. Hope it helps.
Thank you, I also have a lot of trouble in re-installing windows 10.
send your email. I’ll share the stock rom with drivers for the ubook x and instructions on how to install windows 10
My email:
tangohd@gmail.com
no prob. check your email. Windows 10 for the Ubook X is over 7GB so I’d suggest to dont sit and watch the download progress
Woud you mind to send me the stock Windows 10 rom too? My email is david.gabriel.31[at]gmail.com. Thanks in advance!
Thank you so much. Downloading now!
I tried and the installing of windows 10 was good.
1 driver missing but I found it on this forum.
Now I have the ghost touch problems
Sometime it the cursor moves like there is someone touching the screen.
Any ideas?
Update windows 10 until there are no more updates or install Windows 11
I moved to windows 11 but I had problem with h7 stylus pen and bluetooth ear phones.
So I decided to went back to 10. The ear phones now work and the h7 is still stopped.
This is the third time I format and re-install windows 10, the first two times with a microsoft
image, last time with the 7gb image I download from here.
Each time the same problem: there is a ghost that is touching my screen on right part of touchscreen every 10/15 seconds.
Before formatting Chuwi does not had this issue.
Now I tried to change Touch I2C driver with KMDF HID Minidriver for Touch I2C Device
The ghost touches are disappeared but the screen is not touch any more
What kind of drivers have you got on your Chuwi Ubook X 64 for HID I2C?
That’s odd. Since I upgraded to Windows 11 I haven’t looked back. My H7 pen works well too…
Try the link I posted. That ROM is directly from CHUWI
I tried that ROM and ghost continue…
Have you installed all updates after installing?
U have to go here:
Really thx…giroscope now is working back!
This happens to me if I have it charging with ac adapter. It affects alot when im using the stylus. If its not charging, I don’t have problem.
Yes I did. At last I solved with Kinoko files.
(https://forum.chuwi.com/t/ubook-x-cw1535-digitizer-hipen-h6-firmware-needed/15646/2)
Hi guys, that driver package is great! Thank you very much.
Just 1 driver is missing in the archive, here it is:
Kionix CJ9-TJ9-TJ2 Windows Drivers 1.28.3.zip
If you want, I uploaded here even an updated version of the archive from @Faifaifai, including Kionix driver and Phoenix hid update:
Drivers_Chuwi Ubook X_v2.zip
Iwant chuwi ubook x window 11 drives dchpc92@gmail.com
