Corebook X Battery Swollen - Damaged chassis
Corebook X model 2020, the battery is swollen and it has damaged the chassis and the touchpad. I am very upset and frustrated !! I bought it from Amazon USA and I was relying on this laptop for all of my work. What should I do now?
buy a new one
The battery doesn’t swell in a day
@bruzan2025 Thanks for replying to me. But I think this reply is not suitable for the objective of this forum. As we all share practical “correct” replies to help each other, and if we don’t have anything “useful” to add, we don’t have to reply!.
Based on your false comments Chatgpt and Gemini replied with same answer that a “Yes, a laptop battery can swell in as little as a day if there is a significant underlying issue, such as a **manufacturing defect, severe overheating, or physical damage”
Moreover you added another silly comment to go buy a new one? Can I find it easily as a over-shelf medication? or where could I find it, sir?
You’re right, this is a forum for users of Chuwi devices to help each other.
The correct answer is: Sir, please contact technical support.
Good luck with resolving the issue.
