Freebook 13.5 Audio jack and bluetooth headphones not working
Hello everyone.
Just arrived, tested everything and ok, but the audio jack and bluetooth headphones do not work.
I tried the audio settings but I did not find anything that helped me.
Can someone help me?
Thanks.
Send the Serial number so maybe installing drivers could work?
ZFreeBCY4H240302824
I add that after various tests the problem is currently related only to the use with zoomworkplace.
I checked and just in case you can download the drivers here
Thanks for the support.
I downloaded the drivers but the folder is named minibook x, are the drivers also good for freebook? and how do I install the drivers?
Yes they are good, you can install they use the same
