Freebook keyboard disconnected
I bought a PC less than 2 months ago. The assistance I received didn’t help much. The keyboard keeps getting disconnected.
I also installed a program sent by a Spain assistant (the nicest person I had the pleasure to talk with).
The issue still hasn’t been resolved. I need to use my PC for work. Furthermore the return is available only for 14 days (in which the assistance didn’t solve my problem, barely answered).
I had problems with the EU plug. I got delivered firstly an American one, which neither worked with the adapter I HAD TO BUY on Amazon, for the timings. The EU plug I got sent later didn’t work as well.
They told me to ship it to the only available store in Germany. Didn’t answer when I asked if they would charge me for that or if it was on them.
How do I connect my keyboard?
I know that by using FM+esc it should connect, it doesn’t.
I tried the function fn+altgr+Caps lock to be able to write in the keyboard, but I still can’t use the mousepad. (I Can’t select stuff)
It’s been stressful.
I am the nicest Spanish ;). Tell me the ticket number of support with my colleagues. I will ask and see if i can help
Thanks for answering.
I had two tickets opened #13036 and #13031.
The problem of the keyboard has yet to be asked as the support didn’t even answered the others. At least not all of it.
When I tried to get back to them, I got sent “not possible to send the message”.
Find here attached the screenshot of it.
Kindly,
ME
While i see what else i can do
Please have a look at this posts in the last messages, it may be connected to the fact that the freebook does not switch between tablet and computer…
I had already tried that function. It still doesn’t work…
What if we install everything from beginning?, you format the computer and install all drivers again. if that does not work the keyboard may have bad hardware.Then we will think what could be done.
Give me your serial number and i will send them to you.
If you mean the ones from Herobook I had already tried that. You sent me almost a month ago. I installed them all, it didn’t work.
I also tried to disinstall the previous aggiornamenti but it worked for a day or two and stop…
No no freebook and Herobook are two computers different, they have different software.Im just trying to rule out all possibilities before sending it to repair…
Give me your serial number and i will send you the original files that came with computer, if that does not work, is maybe a hardware problem
Note the issue may stem from the Freebook switching (randomly) to Tablet mode. Then the keyboard doesn’t work. No way to manually switch in Windows 11.
I installed Lenovo Mode Switcher and updated Windows to latest and then used Driver Booster for latest drivers. Now it works flawless.
@Wortelstok thanks for steeping by
got myself a freebook for christmas, big mistake, it worked untill I made a update from windows, suddenly keyboard and touchpad are dead, tried to restore the original image got the same issue, on linux it detects the hardware keyboard and touchpad, says its active but there is no input.
from a lot of tests what I found out is the official drivers for windows are not signed therefore they will not be installed even using double driver. On rare occasions we manage to find a workaround and install the drivers they only work until next pc restart.
Overall its a interesting pc with great features but Chuwi drivers are a disaster
Good morning,
I am writing from Italy, I purchased Freebook 360 n100 in December 2024, since then no problem.
Since this morning, at every start or restart, it goes into tablet mode, deactivating the keyboard.
I found that the only way to reactivate it is to rotate the keyboard 360 degrees (tablet mode) and return it to 90.
How can I solve the problem?
Thanks.
TRy to reinstall drivers? Normally thosethings are provoked by Windows updates
Give me the serial number
Good morning, the problem is more or less solved, today however when I turn it on the keyboard does not work at all, it does not light up, and it does not even switch to tablet mode so I can not even write, suggestions? Thanks
ZFreeBCY4H240302824
The problem comes back again and lasts for a few days
You’re asking a user who is: not active: ChuwiESnotactive, who isn’t going to answer you. What’s the problem ?
You can download the operating system and drivers from the Chuwi website, in the “Support” and “Downloads” sections.
or
You should contact Chuwi customer support: service@chuwi.com
I’ll ask you the questions again.
Have you reinstalled the operating system or drivers ?
I think it’s a problem with the connection between the screen and the keyboard
No
