Anyone experiencing random reboots. Just got this Chuwi Gemibook Pro for Christmas and so far I have been experiencing a random reboot. Usually occurs while surfing the web. System will go dark, and the boot screen will appear.
Greg
Greg
The system is up to date through Windows Update and the drivers and such offered there. I haven’t installed any driver software like the Intel driver and support assistant. I am up to 22H2 on Windows 11. It rebooted on me just prior to checking the forums.
Happened to me too on a Chuwi Minibook. The odd part is it only happens when I’m using the charger. My temporary solution is to use it without connecting a charger, and just charge it after. A friend suggested resetting the computer. I have not done that yet.
I reset my laptop this evening. Will see what happens. I hadn’t had any random reboots in the past couple days. Instead, I started getting blue screens which started after trying to do some intel updates. Last night I had two blue screens within about 20 minutes of each other with the stop code for whea uncorrectable error. I reset the computer tonight and have been using it for about 45 minutes now and so far, so good. The only thing I use it for is surfing the web on Microsoft Edge. I really want this laptop to work. I love the screen and the size. I’m a little underwhelmed by the processor but like I said it’s for browsing mostly. I have a couple more weeks in which to return it. If the reboots and crashes continue, it will go back.
