Gemibook XPro CW1574 power on does not boot need BIOS
hello i have here i think BIOS isssue need to request for that bios serial number JGeBXPCY2H240602377 thank you
Because you think you have a problem with the BIOS.
How old is the laptop?
What version of Windows do you have?
Only support can tell you if there’s an update.
i dont need update i nedd firmware to flash
You only answer the last question.
You mean the laptop’s led light comes on but nothing is displayed on the screen
yes thats what i mean i need bios firmware to flash corrupted bios
I can’t see your computer, so I have to ask about its status.
You can enter the BIOS: ???
Because you think you have a corrupted BIOS, what have you done to make it corrupted ?
its my client laptop they want their unit to be repair, one day they said the laptop power on but wont display anymore then i try all the guide on chuwi but thats not what its the problem the unit wont boot up because its a bios firmware got corrupted causing the unit wont boot i check all the posible voltage then its showing good but when i check the current draw its just a low current draw meaning the unit just only powring on but no post or not waking up the cpu thats whay i need bios firmware to confirm that the bios is the issue here i hope i can get support from you because i have so many customer need support from your brand so that you can make more sales and not shaming your company but helping you to your sales and service hope you can do that to all thats is contacting you and needed your help
As far as I know, this is a user forum; Chuwi support doesn’t monitor it.
