My tablet shutdown while in use and will not reboot. I have tried several different presses of the power button and in combination with volume controls. The power light was initially red so I charged to green. The tablet now only has blue light after long power button press. No other press of the power button turns on the unit or any other lights. As it now there is no power except the blue light. Please help. Tablet purchased directly from Chuwi store less than 60 days ago.
This is a user forum; no one from Chuwi monitors it. You should contact Chuwi support: service@chuwi.com
A service request has been made and awaiting a response. I am trying all avenues hoping someone has a resolution for this issue or that Chuwi will respond. Thanks
If it runs on android try the following; push the power button for more than 40 seconds till you see the startlogo.
I have the same problem, my chuwi Hi10max not tun on again, my warranty finished some days ago of my first email. They don´t answer then I write to chuwi.com they say that i must contact support in a email to all. But support answer your hi10max ins’t in warranty time. Here is the unique place that coud help me. Please someone? The battery charge normally. but didn’t turn on . I press button to on several seconds.. , the same with button to turn on and volume but nothing. I think that must be more people as me. Help us please!
I think they’re trying to tell you: you have to pay to get it repaired.
The problem may be a hardware component
You can ask at a phone repair shop in your area.
