I do not know whether I have a hardware or a software problem. I have replace the original win with a win10 and for a year or more it have worked just fine. But suddenly, the keyboard did not connect anymore. The two green light did not light up when starting up the computer, and I can not enter anything on my computer using the keyboard.
An alternative wireless keyboard and an old fashion wired USB keyboard still works fine. But I want my original cover keyboard back ;0)
I have bought a new keyboard but is still waiting for it due to the (real life) virus in China. In the meantime, I was wondering if I have a problem with a driver or something like that. Maybe I’m not the only one struggling.
Coincidence apart, I have the very same problem from today
Running Win10 1909 …
Ordered a new keyboard on AliExpress but there are not many resellers left…
It is not the first time that I read it. There have been quite a few cases where the keyboard suddenly stops working due to some internal failure I imagine.
The only solution is to buy a new one.
It would not hurt if you put the purchase link.
Sorry to be late to reply! I’ve found my keyboard at this store on AliExpress: https://www(dot)aliexpress(dot)com/item/32841972500.html
Seems there are still a few left, in purple. (I was afraid about the color, but it’s definitely not a problem )
Hi
Sorry for responding so late. The new keyboard solved my problem. ‘Opening up’ the Old keyboard made it clear that a small wire was broken. I don’t think it can be fixed.
Per
