LAPBOOK PRO SCREWS
Worst laptop and customer service. I’ve been trying for months to replace the screws on my Lapbook Pro, but there was no answer at all and it was completely ignored.
They claim to have sent me screws but that’s a lie because they didn’t even ask for my address & this was more than 5 months ago.
My laptop is falling apart and they do not help.
hinge completely broken.
Not recommended. 0 stars.
Do not buy.
Sorry to read this. It’s a shame that because of a few screws you can’t enjoy your laptop. You must insist on service@chuwi.com
yep, mine were loose from the factory as well. I was lucky because I had a few screws from an old iPhone repair kit and the screws lucky were so similar that I could replace the missing ones. I also took the opportunity to remove all the loose ones and thread lock them before reinstallation.
Do you know the size they were please?
Yo tambien he perdido 3 tornillos que han desaparecido sin mas. Ahora el equipo no carga , la verdad es que es un portatil precioso pero la calidad es muy muy deficiente .
