For my convenience, I need to put the my tablet in legacy mode.
I just switched boot mode to Legacy, but its not working for some reason.
How can i put my tablet in to legacy mode?
You must disable secure boot.
Yes, I disabled secure boot and its still not working.
What are you traying to boot in legacy?
EasyBCD cannot use some functions unless it is legacy.
I tried rEFInd but touch function are not working. (I enabled touch in config)
I want to setup EFI boot manager that does not use keyboard / mouse
the touch in rEFInd is not working because the driver (goodix) is not on this ISO. Anyway, i think your problem is on BIOS setup, the only thing you need is to activate USB keyboard support in the BIOS setup.
I dont have keyboard for my tablet, I only just want to dual boot without using keyboard and mouse
Also, USB support is turned on in default
EDIT: I found guy that have same problem
Anyway, I found way to access another os using USB.
For multibooting peoples:
Installing (One time)
set timeout=0
menuentry 'Boot'{
(Boot code here)
How to boot:
shutdown /r /o /t 0)Maybe you can make batch file that do 1~3
(UPDATE) I found that WinRE can select device to boot. process changed little bit.
