Serial number: ZMinBXHY4H240201997
Buy from Aliexpress
I use a steam deck usb c charger and plug it into the marked port for the charger to charge my minibook, it was charging fine and i remove the usb after full charge update my Windows. The next day it wouldn’t charge or turn on, did i kill the battery?
Will replacing the battery help?
did you try using other ports? or charging without the deck?
Yes i tried the 2rd port still nothing.
Then , as you bought in Aliexpress. You need to contact the shop, and ask them what is the procedure in this case. I am sure my colleagues who work in Aliexpress will offer you a solution if neccesary to repair.
They gave me a full refund without the need to return the laptop which is good but i really like this laptop so i want to fix it is possible.
You can contact the shop again, and they will probably help you to send it to be repaired. In this case you will need to pay for all the repair, as they gave you a full refund.
