I tried replacement the m.2 ssd 256 gb width a ssd m.2 mve pcie 4.0 1 tb and dont work, doesnt detect the ssd, wich ssd work? only sata III ssd m.2 2280 work? and wich models?
Yes only m2 sata SSD Work on the xpro the pci lines are Not connected to the m2 slot.
Hello @LordValium could you please share some compatible ssd´s URL?
Im trying to find some one compatible, but not much info yet on internet for gemini x pro
Amazon.com: Western Digital 1TB WD Blue SA510 SATA Internal Solid State Drive SSD - SATA III 6 Gb/s, M.2 2280, Up to 560 MB/s - WDS100T3B0B : Electronics
Hi. smg like this should work. You need m.2 SSD with SATA. NVME will not work
