New cooling system
How did you mount that cooler cause for mine at least with the 5800H it has triangle shaped mounting bracket/holes, so what did you do to mount that cooler?
el montaje esta realizado a traves de imanes de imanes de neodimio
Seems a new cooler for the same case
I see it’s intel, but perhaps it has the same three screw layout
Interesting…but if the mounting is compatible (and I have the feeling it’s not) I don’t see it being easily available outside of the final product…can we now buy the cooler of our 5800H outside of the whole product (directly from Chuwi, or any other seller on AliExpress or similar sites)? No, and I don’t think it will be any different with the cooler in the new product.
@ricky You mean you want to buy the cooler of RzBox?
Yes, is it possible to buy the cooler of the RzBox?
And since you are here I’ll take advantage and ask you if the mounting system of the cooler of the new E10 ETBox is compatible with the RzBox (and if will we be able to purchase it).
Thank you
i will ask on Monday and see
Thank you very much for your reply.
Have a great weekend.
@ricky I asked Tech they told me they used the same case.
Can you show me a picture of your cooler and the parts you need a replacement? Make a round circle on them so i check if we have still stock. Also provide the Serial number
The fan + heatsink is the one of the RzBox.
More importantly it was interesting to know if the new cooler of the E10 ETBox (the whole fan + Heatsink) has the same mounting system of the RzBox, but judging from your reply maybe not.
1- To be sure could you please ask the Tech team all the distances in millimeters between the holes where the screws of the heatsink attach to the motherboard on the E10 ETBox?
In the picture attached you can see marked by the green circles where the screws of the heatsink is attached to the motherboard n the RzBox.
2- Are these holes of the same distance between them in the RzBox and E10 ETBox?
Thank you.
R
ET Box is exactly the same, is a colaboration with Acer so pieces are the same. So it should be valid for RzBox
We only have stock of the black fan, not the golden tubes. I asked and Pieces for ET box have not been purchased as it is a new product we do not have yet replacement for that.
That’s very promising! Thank you for the reply!
I’ll ask again in a month or so, maybe by then the cooler might be on stock and purchasable.
Thank you and have a great weekend.
Hi ! Any news about this furniture? There is a way to buy on your store from Italy?
No news, yet is still no on sale.
Sorry I’m late to this
I’ve already been though this private chat with Chuwi
Sent several photos, agreed price. Been sent the wrong part (Just the Fan)
Then told the part is not available for sale and refunded
Of course it wasn’t as straight forward as I’m typing (was a lot of effort for nothing)
The three screw configuration is used in some HP systems
ā€œHP EliteDeskā€
I got one new on eBay for £5, probably will not get a chance to test or look at it for some time, will need some modification for the fan, might not fit but worth a try
Hi Maria (Chuwi),
Just realised it was you helping me out in February when we had a dead end, hopefully Ricky will have more luck.
Exactly the same enquiry a few months on.
Thanks all
Stu
I asked, not yet available
Very interesting, good catch!
Could you please share the link (maybe in a private message since I don’t think direct links to online shops are allowed).
5 pounds is very cheap for a the whole heatsink, if it’s compatible with Chuwi’s RzBox that would be amazing. How come you haven’t tried it yet? Are you waiting it to be delivered to you?
Thank you!
Edit: I’m afraid the mounting system of the RzBox heatsink is different, the holes might be distanced more far away between each other compared to those of the Hp EliteDesk system
