Screen flickers
Screen flickers.
Yesterday I bought a CoreBook X and today when using it in the office I noticed that the screen flickers very aggressively, searching the forum I find that other people also have this type of problem… Is it a factory error or could it be that Will it be fixed with a windows update?
:cry:
I have the same problem, I bought a CoreBook X at the beginning of February 2022. I need help!
Apparently the brand support solved it for me, they say it’s a problem with the Wi-Fi antenna and it has to be replaced. They applied a cost of 25USD for the antenna and shipping to the US.
Thank’s for the information, I tried contact them in Mexico, but they don’t answer me. I hope ASAP they solve the issue on my laptop or I will return the product.
Try to contact technical support at the following email address “service@chuwi.com”, tell them that you have problems with the screen and they will probably ask you for proof of the failure. I shared a Google Drive folder with them.
