Hi all!
I’ve recently bought the Ubook Pro N4100 and I like this device very much. I set everything up, I installed all updates that Windows found. Now it says Windows v18363.
Everything works perfeclty fine, (for example, I have the “Touchpad Settings” in the Control Panel, so I assume that I have the keyboard drivers updated).
The only problems I have are:
- Touchpad - when I move the coursor quickly, it moves a little bit more even after I stop touching it. One user reported the same issue on this forum. This is not a big deal as I use bluetooth mouse for 99% of a time but i’d be nice to have that repaired.
- Occasionally, the “closing cover=sleep mode” and “pressing the button to switch off=sleep mode” doesn’t work. Instead of going to sleep mode, it goes to, I don’t know, a super deep sleep mode, so it’s impossible to wake the tablet on
When it is in the proper “sleep mode”, the blue LED flashes slowly - that is ok. But when the tablet is in the wrong, deep mode, the LED is either switched off, or switched on. In this situation, I cannot wake the tablet on using default steps - like pressing the button, clicking the mouse or typing on the keyboard. The only way to wake the tablet is to long press the button until the blue LED lights on (or, when it was already on - to go off and on again). Then, another long press on the button to switch the LED off. And then, the third long press just to “turn on” the tablet - then, the CHUWI logo showes up and the system boots up.
This situation often happens when the keyboard is attached, it never happen when the keyboard is unpluged.
I turned off the “Fast Boot” in the power management menu and that helps for the first two, three days. Maybe something turned that one (a Windows update) ?
Second thing, once I have all set up and working, what should I do to make a backup of the system? For example, something crashes in the system and I need to reinstall Windows - are the tools present in the Windows enough to make it? (is there like "recovery partition etc?)
Or maybe I need to create such recovery partition, or collect and keep safe the drivers and a copy of Windows that I found here on this forum?
Thank you for your suggestions
