I bought a new memory module for my UBox but the device uses the memory installed in channel A only.
The new module is:
Lexar SODIMM RAM DDR5 16GB 5600 MHz, 262-Pin SODIMM, 1.1V, CL46-45-45-90
Reference number:
LD5S16G56C46ST-BGS
So far I tried to boot the UBox this way…
Try 1:
Channel A = original module
Channel B = new module
Result: Only seen 16GB from channel A, expected 32GB from A+B
Try 2:
Channel A = new module
Channel B = original module
Try 3:
Channel B = empty
Result: Only seen 16GB from channel A, as expected
Try 4:
Channel A = empty
Result: Does not boot !!
Try 5:
Channel A = empty
The new module is same brand and almost identical to the original module that comes with the UBox.
It seems that channel B is not working properly because the device does not take the memory that I install on that slot and also the device does not boot if one module is installed on channel B only.
Is this a faulty unit maybe?
Please create a new subcategory for UBox in this forum.
Thanks,
