Hello, I have a problem with USB C activation on bios, of which my PC does not support fast charging by type c, how do I activate it in the bios, I enter advanced after system component in USB typeC … thank you
Have the same problem
i had the same problem which i also described here on the forum. Usb-c was broken, the whole motherboard needed to be replaced. I waited more than 60 days for the repair.
