I found on the Internet how to speed up a little the N4100 CPU installed in UBookPro. It all comes to changing the Power Limit of the CPU. The default limit is constant 6W (a little more on demand), but it is possible to change this to 10W, 15W or even unlimited.
Changing this limit will result in shorter battery life but it should improve the performance of the tablet.
WARNING! This will increase the amount of heat that is produced while using the tablet. I don’t take any resposibility of any bad consequences caused by using this method. Increasing performance with this method is recommended when you use the tablet for lightweight work (opening apps, videos, office, etc.) and you see some fps drops, slows down etc. - this way, the processor will use more power only for short period of time (when opening the app, playing animations) so the heat should not be dangerous. It is not recommended to use this method when you play games or do heavy work, when the CPU is used in 100% for the most of the time - this may heat up the CPU to high temperatures and makes the tablet go dead eventually.
What this method does is basically editing the power limit loaded from BIOS to the memory. This means that after reboot, you need to use it again if you want to change the limit again (it does not do anything permanently).
Personally, I wouldn’t recommend go further than 10W (as the default limit is 6W) but anybody who wants to use this method, makes it on his own risk. You need to control the temp of the CPU (for example, use CoreTemp app), not allowing to go too hot.
- You need “RW everything” app, https://rweverything.com/download/
- Open the app, and in command promt, you need to enter one of the following commands:
WRMSR 0x610 0x0 0x00DD8A00 - sets the limit to 10W
WRMSR 0x610 0x0 0x00DD8F00 - sets the limit to 15W
WRMSR 0x610 0x0 0x00000000 - unlimited
Then, you need to enter this next command as it is some kind of second power limit:
W16 0xFED170A8 0000
And that’s all. You can close the app and check if the tablet works more smoothly till you reboot it/put it to sleep.
As mentioned above, do it on your own risk!
